S3-Compatible Storj DCS Origin for Content Delivered at the Fastly Edge
Kevin Leffew
December 21, 2020
Fastly is an edge cloud platform that processes and serves application data as close to end-users as possible. Fastly's highly programmable CDN solution is used to accelerate content delivery to end-users in a more efficient manner by caching it at edge nodes across the globe.
These edge nodes are referred to as Points of Presence, or POPs and are strategically built in well-connected locations across the globe to reduce transit time when delivering content to end users. Each POP has a cluster of Fastly cache servers that enables compute at the edge as well.
When end-users request object data, Fastly delivers it from whichever cache location is closest to each end-user.
https://www.fastly.com/network-map
How Origin Servers Work in CDNs
The first time each Fastly cache receives a request for a content object, it fetches the object from the appropriate origin server. If multiple origin servers are specified, the cache will distribute the processing load for the fetches across all of them (based on the configuration criteria set by the user). After the content object is fetched, the cache stores a copy and forwards its response to the end-user.
Caching basics first request
Each time after the first time an end-user requests the same content object again, the Fastly cache fulfills the requests by retrieving the cached copy from storage (or memory) and immediately delivers it to the end-user--the fetch step to the original copy is not repeated until the content object either expires or becomes invalidated by the customer.
Caching basics subsequent request
How Does the Storj DCS Origin Work?
Storj DCS, the new S3-compliant storage solution from Storj, can now be configured to act as an origin for content in Fastly.
To get started, simply sign up for a Storj DCS account, set up an S3-gateway, and voila
Share this blog post
Put Storj to the test.
Start your trial
product guide
